Iburst wireless connection with billion 400g router
artistzzz
I have been searching on the forum and have not found the exact answer on whether billion 400g router can be used for Iburst wireless connection as buying an Iburst wireless modem is quite expensive.
I am not sure about Billion 400g. What I can recommend is Billion 74002 GXL. It works like a bomb with Iburst dongles.
So we need an Iburst dongle anyway? how much does that cost? any alternative? their hardware are very expensive.
It seems as if you don't want to buy the iBurst Modem, but buy a router instead?
That is impossible.
The iBurst modem is the only way you'll connect to their network.
Without the iBurst modem, you will not connect to iBurst, period, and yes, get the desktop modem instead of the USB devices, they get much better signal.
The only thing that the Router will do is split your internet wired and wireless to other devices which are plugged into it.
Any brand of router will do the Job, iBurst is not dependent on your Router...
