Hagu13
Hi All
Please help:
My daughter has a 2 year old Celeron. When it was built we moved the old IDE drives across from her old PC so she has an IDE DVD writer and 40GB IDE HDD running XP.
My machine was identical except I had a 120GB IDE (XP) and a SATA DVD-RW. Recently I added a 500GB SATA and installed Windows 7, and dual booted, then later I formatted the 120GB drive and used it for storage.
Now today I decided to clone the 40GB drive onto the 120GB drive for my daughter. Plugged it into her machine as slave and it hangs after PCI device detection. Tried all configs of masters, slaves, cable select, back to as found and PC will not go past that point. Tried 2 different IDE cables, no change. Have also cleared CMOS and played with BIOS settings but nothing.
Then moved across to my machine and tried IDE there. Same as daughter's machine- if an IDE drive is detected- either drive, either cable, master or slave, it hangs in the same spot.
I only have IDE drives available for that machine and can't afford SATA ATM. Also need to recover her data anyway.
Suggestions, please...
Please help:
