HapticSimian
- Apr 22, 2007
Turns out the battery terminals were not properly settled.![]()
You know, you don't have to bleat out EVERYTHING on the 'net. Save some self-respect & keep quiet next time, man.
your first problem...its a VW
OK,
ignition problems again, turns out it's not the battery terminal!
Going to get the celenoid replaced, It must be that.
The car is 12years old, and this is the first problem its having. quite impressed
Thanks for the reply Oom.Stokstert
I'll be taking the car to a garage, am tired of struggling to find the problem.
But for now, I'll use the temporary solution with the flylead as mentioned if it works.
Hi,
I have taken my car to a mechanic yesterday, turns out the ignition switch was faulty. they replaced it and now the car is starting very quick, better than before!
R815 later though..
Hi,
R815 later though..
I'll bet the greater part of that was for labour, right?
Same thing happened to me. Had to buy the new ignition switch which was R350 and labour was gonna be about +R500. But I did it myself.
The ignition switch was about R450, Guess the labour was for the rest of the amount.
Mine was a 97 Audi. I was still in Centurion (2007) that time so I took my car to Audi Centurion. They said it takes about 2 - 3 hours to replace. I took 30 minutes to do the job.
+1 for learning to work on your car yourself!!![]()
