ChrisThomas
Hi Guys,
As the title suggests, I want to install a sound system in my 1972 bug, that still has the Generator instead of an Alternator. I just wanted to see if this is not a good idea, if I should have it changed to an Alternator first. I've tested the output of the generator and if revving the engine a little, it will put out 14.7 V constant. This drops when the revvs drop and the output will be about 13.7V.
I want to put in a normal headunit, 4 speakers and a small Kicker amp, any thoughts?
I've had another beetle in the past which was also a '72 and it just had constant electrical problems, it had sound installed, not sure where or by who but was a similar setup to what I'm describing, it also has an immobilizer and central locking which is what I think caused most of the issues but the overcharging of batteries and all my other nightmares continued after I took all of that out.
Anyways, this Bug has been a superstar and hasn't given me a moment's trouble, it's been fully restored and runs great. I'm just nervous about causing problems. Any ideas?
