Intel Demonstrates Simple Liquid Cooler
Farquaon
USA
Intel Demonstrates Simple Liquid Cooler - AMD's END!
With the release of details concerning their new 'Core Microarchitecture' lineup, one would think Intel has done enough to get the boys over at AMD pulling all-nighters. Details have just been posted over at Hexus and bit-tech concerning an interesting new liquid cooling solution from Intel, which was demonstrated cooling a stock 3.8GHz P4 EE chip clocked up to 5.0GHz. Although that's not difficult to do with expensive, complicated, and at times messy kits from 3rd party vendors, you'll be impressed at the way Intel did it.
The Extreme Edition P4 was cooled by a very small, very cheap solution Intel is calling their "Advanced Liquid Cooler". Using a case fan and some clever metal tubing, the tiny water cooling system kept the CPU temperature well within thermal limits. The system has no parts or liquid that needs to be serviced and looks to have a relatively simple install procedure:
"It consists of a block unit which attaches to the processor. This contains the copper core which makes contact with the CPU, as well as a centrifugal pump which uses a DC brushless motor. This pumps the water up through solid metal tubing to a more traditional radiator, cooled by a 120mm fan. The integration of the cold plate improves thermal performance. The main body of the unit is made of injection-molded plastic."
Clearly Intel is trying to capture the attention of computer enthusiasts that have flocked to AMD in droves over the last few years. With an anticipated release price of only $50, Intel is bringing simple liquid cooling to the mass market. It's still unknown if they will offer the new cooler inside 'retail box' processors or provide any sort of warranty waver when overclocking other chips with the cooling system.
Interesting, I think alot of people might take up the old religion again :rolleyes:
Hexus.Net
Bit-Tech
For Images of The Unit
Edit: Added image link
