Intel DX79TO Boot problem.
P3wP3w
Sandton
I wondering if anyone knows anything about what is happening:
I have a Intel DX79TO with a Xeon E5-1620 installed. Bios is updated to the lastest version. The BIOS picks up all the drives, ram etc. The problem comes when selecting first boot device or even to boot from USB to install Windows, the screen after post just remains blank with a 0_ in the bottom right corner.
Anyone have any idea what is happening?
I have the same problem with my intel DP67BG board, have i7 2600 installed with 8gb of ram. I have a 560ti and just got my 780 GTX. Plugged in my 780GTX and the intel boot screen shows up but after that i just get a blank screen with 0_ in bottem right hand corner. I plug my 560 ti back in and it works fine. So im not sure if my mobo is compatible with my gfx card or if the card is faulty or if i wired something wrong when i put my new PSU in. Have you found a solution?
