Intex easy set pool sand problems
gnilrac
Hi everyone,hope you had a good Christmas.
I'm looking for advice concerning the large Intex easy set inflatable ring pool.
It comes with the filter pump and I've got a hth floater keeping the water pretty clean .
My only problem is the sand settling at the bottom of the pool.
Any ideas how I can vacuum? or get rid of it without buying other accessories?
It's only gonna be up for the holidays,been great birthday but the sand on the floor doesn't look nice
Would appreciate any suggestions,not looking at buying expensive equipment.
Thanks guys
Ag,for the price and maintenance for holidays,it's great.
Plus I got a answer to a pool vacuum that hooks up to my garden hose only R130 at builders .
So it's ok,really, but not to keep whole year...
I'm also gonna try this,while they holding their beers
Theres a bit of a trick you can pull with this.
Two people rotate on the outside of the pool in the same direction, just be careful not to go too fast to make the water spill out. In a few minutes you should be stirring the pool nicely, and the sand and other debris will gravitate towards and settle in the middle of the pool.
Now you just need a short length of hosepipe. One end in the pool one end outside, and pretend to steal petrol. Preferrably the outside end of the hose should be lower than the part inside, but give it a whack and report back :)
