If you start getting confused it means the conversation you are having with the installers/suplliers is not at your level and the installers/suppliers are unable to bring the conversation down to your level.
You want something to power your essential components for 4hrs, you know your total consumption a day but you don't know the consumption for the specific components you want to power for 4 hrs.
Get a Sonoff plug or the the Kill a Watt thing from Geewiz, plug it on all the components you want to power, set it to kWh mode and measure the kWhs used over 4hrs, the same kWhs from Eskom are the sand kWh your battery must have, there will be inefficiencies resulting in losses and for that you will need to overspec your battery.
But in very simple terms, you use 5kWh for 4hrs with Eskom, you need 5kWh usable energy from your battery to power the same load for 4hrs without Eskom, as I said you need to compensate for the depth of discharge, energy losses, self consumption by the system to get as closest as possible to the size of battery you require.
10A - 2200W Max Remote ON/OFF–Turn electrical devices on/off from anywhere App Support–iOS & Android mobile App Sync Status–Realtime device status Timing–Set timers to turn on/off Share Control– with your family Scene–Turn on/off a group of devices with one tap Voice Control–Works with Amazon...
www.geewiz.co.za
Measures electricity usage Wattage: 0~3300W (Max 3300 watts) Voltage Current: 0-15A (Max 15A) Power Factor Electricity Cost ***NOTE: The counter on the device will reset when it is unplugged from the wall.
www.geewiz.co.za
