Why?Measure your appliances , you will only get maybe 600w from that .....
Why do you say that?Measure your appliances , you will only get maybe 600w from that .....
A 2000VA inverter should do a lot more than your 600WWire thickness, heat loss etc etc and manufacturers exaggeration....
1200W according to the specs.A 2000VA inverter should do a lot more than your 600W
Looks like you are doing a little exaggeration of your own with your 600W figure.Wire thickness, heat loss etc etc and manufacturers exaggeration....
