Adeptus Mechanicus
Inverter (Kodak OG6.2) displays some odd battery discharge behaviour.
2 examples:
1) Boiling a kettle (top is load and bottom is battery draw in watts at same time)
2) Idle household usage (top is load and bottom is battery draw in watts at same time)
- Before I had PV I would have a constant 20-60w drain on the batteries.
- With PV this behaviour is now increased while I'm generating out of the panels
- Output is set to SUB and charge priority to use solar to charge battery first and allow utility to charge battery. SBLUCB
2 examples:
- Why would it be pulling 419w out of the battery when there should be sufficient PV and grid?
