Hi guys,
I am realy really stuck and need some assitance.
I am trying to upgrade my iPad2 from 4.3.1 to iOS5 and cannot get it right. I have now downloaded 2 different versions of the iOS5 firmware from 2 different sites and even got the file from Digicape.
When i try and do the update i get and error halfway through (3002) i then try the restore option using any of the files i downloaded and the software extracts but the minute it confirms the update with the Apple Servers it kicks out an error message saying that this device is not eligible for this build.
So i surfed around and found out that some people are having thesame issues due to a change in the the hosts file, i ammended it in several different ways as recommended by several sites, either removing the gs.apple.com reference or # it out or even ammending the adress listed in it. Nothing works, i keep getting the same error.
I downloaded the absolute latest version of itunes this morning directly from the apple server so i dont know what more to do....
I am completely stuck and dont know where else to turn... Does anyone else have an idea ?
PS all the websites i have checked, have said that the above fix works in 95% of cases, mine however doesnt seem to work.
PSS i bought the iPad about 6 months ago off Gumtree from someone who had been to the States and brought in 2. One for himself and one for me.
