iPad/Safari issue with myBB forum
Madhawk
JHB
Sometimes when I go onto myBB forums, using Safari on my iPad the pages don't load correctly.
I have to reload or sometimes close Safari and open it again to get it right. There are times even that doesn't help.
I downloaded Dolphin browser and I get the same issue. It's not consistent.
I browse other forums without any problems. I also clear history and data regularly.
I also find Safari to be slow to browse with on a iPad. I find myself reloading pages to finish a page from loading correctly.
Anyone else having issues browsing myBB on their iPad with Safari?
Here's 2 pics of how the pages load on the iPad. (myBB forum)
It works fine on mine. Maybe you need to "pinch" the screen using two fingers for it to fit perfectly
Looks like it isn't loading up the style sheets properly. Maybe just sometimes a bad connection to MyBB?
I have the occasional problem with the stylesheets not loading properly but a cache flush or theme change soon sorts it out. Happens with a couple vbulletin sites I frequent but fortunately MyBB, unlike the others, is Tapatalk enabled.
I have done that, but it doesn't change things.
I do change the theme and that sometimes helps. I will get Tapatalk when I load more money onto the US account. $4.99 is a bit steep for an app. Thanks!
Not an iPad issue, get the same on normal browser as well as Android from time to time.
Normally linked to some network issues, in my case torrents can cause this type of page loads.
I use the $2.99 version instead of the more expensive HD one.
I use Chrome on my laptop and have never come across this, also I don't use torrents.
I think the HD version will be worth it, especially on the retina display.
I'm just glad to know that I am not the only one with the problem. Thanks gents!
So I bought Tapatalk for $4.99 from the iTunes store. I don't like the interface from Tapatalk too much, so I use the "Browser" option instead.
Guess what? The same thing happens on Tapatalk while using the browser option. Sometimes it loads correctly and sometimes it doesn't.
I clear the data and it still doesn't make a difference. I am registered with 2 other forums and this only happens with myBB.
I've heard people say there are problems with the HD version of Tapatalk. :o
