iphone 4s battery replacement
midnightcaller
gauteng
good day,
i need to replace the battery on an iphone 4s.
is there a place i can go to, to have this done?
is there a kit i can buy and DIY the replacement?
good day,
You can buy a kit from iFixit. Will be a bit expensive to get in South Africa I suspect.
good day,
There are also places on ebay and BoB but just be warned it is a toughy one to do as you need to completely take the phone apart from the back to get to the screen. You just need patience and it will get done.
Will it actually be worth it? You can get a 2nd hand 5 for about R2500 - R3000
Just looking at the scenario a bit different?
