IS acc heavy DC++ connection reset issues
jjtoymachine
Randburg
ok i have an IS account and want to dled my local 30GBs but when using DC++ on the local hub i get constant resets which i did not get on the SAIX account. What good are the 30GB if you cant use them??
Anyone know how to fix this issue?
Where is the DC++ hub running from? Which network ie. saix,uunet,is ?
Theres your issue Im pretty sure, SAIX and IS, with SAIX being the bully.
I think its definitely related to the peering issue.
The problem in SA is that nobody is really willing to share their local torrents info.
You are either IN and loop, or OUT of it ...
the problem in sa is not that people dont want to share, its that uploading eats into their cap. if the cap only applied to downloading, then there wouldn't be this problem
same problem here with IS account, dc resets and sppeds are slow.
Saix based accounts however are fine, plus I get max line speed
JJ" - got same problem, I have 30gb but cant use it :(
