Is my radiator fluid too low?
InternetSwag
Not a car guy, so not sure. But this is a 6 month old Baleno. Checked inside and saw this. I suppose the rest of the fluid is in the radiator itself. Should I just leave it as is? Since my 1 year service is in 6 months
What does your owner manual says about the fluid marker?
My wife Xtrail owner manual shows this picture
Simple, if you have to ask on a forum, then Yes.
Wait till the engine has completely cooled, open the steel lid on the front (radiator), check the level, if you can't see anything, then fill it to just before the neck stats. The one bottle looks like wiper fluid and other radiator reservoir, fill both. On most car manufacturers, there would be a line at the top of the bottle that says MAX.
6 months old and it's already leaking... Cheap Indian Suzuki crap. You definitely have a leak. Take it in.
