Is using RouteSentry going to help keep international data usage down with torrents?
Threepwood
Because RouteSentry splits all your data over International and Local on an IP level, surely if Torrenting, data downloaded from local peers would be carried over the Local connection?
Will this work as expected? Anyone tried it before? If you have please give your result, and if you haven't please start trying now...I'm going to.:cool:
Routesentry will route data according to it's destination (local or international). As long as the peers/seeds are located locally (ie. within the IP ranges specified in the Route Sentry Config) your local bandwidth should be used.
