ISP choices based on line sync speed! Help!
DeatheCore
I posted this on the Sticky but there were no replies so here goes.
I need some advice... for the past few years I've been paying for Telkom's "4-10 Mbps" ADSL package, well in the past 1-10 Mbps, but anyhow it only syncs at 2 Mbps, which is fine for me. I'm not really willing to downgrade to 1 Mbps after all this time and feel the snail-paced interweb browsing.
The problem is that it's extremely difficult to choose an ADSL Bandwidth package to match my 2 Mbps line speed. So far the best deal I've found is Afrihost's 25 GB double data special at R475, but I've been looking around at different uncapped packages. I like to use local news servers to grab a lot of content and in my experience, SAIX local is a lot more stable and reliable than IS or the MWEB news servers. so I was considering the new Telkom Uncapped 1 Mbps package due to no restrictions being placed on local traffic. Another option I was considering was to go with MWEB's Uncapped Bigtime Surfer 4096 kbps Data & ADSL Line rental for R899 which I consider to be a good deal. I must say that Axxess with their rolling window doesn't look appealing at all...
But that's just what I think.. anyway, I'd really appreciate it if I could get your opinions about which Bandwidth Package and ISP you all recommend for my 2 Mbit line (sadface)
Feedback would be greatly appreciated!
If you are sure you dont need more than 50gb per month rather stay clear of uncapped.I would go the afrihost route.If your budget will allow it you could supplement it with one of the telkom capped packages.
I'm quite sure that 50 GB is not enough per month :) and other than uncapped accounts, capped packages are just too expensive :/ From what I've heard MWEB offer the best throttling/shaping policies to do with their uncapped accounts.
Well from what I have seen, most isp's haven't started offering mid packages. So its up to you whether you want a 1mbps/4mbps connection. For the price difference, I would reccommend the 1mbps mweb uncapped package as you should be able to do well over 50gb a month without too many problems. Then with the money you save for not going 4mbps uncapped you get yourself 5-10gb capped package from telkom/afrihost/webafrica and use that when you don't want to wait for something to download.
I hope that helps
