It's not pretty - but it works
Newsfeed
MyBroadband Newsfeed
Staff member
If you read MyBroadband regularly, you will know two things:
  • We once bought an Ethereum mining rig.
  • We once dismantled said Ethereum mining rig for its graphics cards.
I scored two Aorus RX 580 4GB cards from the rig, and one was put to work in my gaming PC at home.
The other lay dormant in my cupboard, and while its sibling collected kills, it collected dust.
So $30 for inferior cooling when you can get a replacement for $20. Only issue is the SAPO.
Turn turn the fans around and you'll see a difference in Temps. Instead of sucking the air from the gpu cooler get the fans to blow on them.
Why would you install fans blowing away from the rad?
For the same reason he first installed fans that were physically larger than the card and extending past the connectors then was amazed that in couldn't slot back into the mb.
Thanks for the feedback.
I was concerned about the fans' power cables and rear brackets being in contact with the GPU's heatsink (potential damage to the fans) - but I will definitely try the fans the other way around and report on the results.
The fans have little slots and guides built in so you can cleanly change the routing and which side the cables come out of.
Yes: turning the fans around was easy and they fit well - but it did not make much difference in terms of temperature and performance.
Since then, I purchased a Radeon RX 5700 XT (MSI model with the blower cooler) and it is more than capable. Especially in Age of Empires II :).
Wololo.
