Go to System preferences, international. My guess is your chinese is above English, and iTunes picks this up. Drag English to the top. If it is already at the top, I have no idea
If it is already at the top highlight the icon - right click and choose Get info (or command+i) and head down to languages (under preview). Make sure it's using english.Go to System preferences, international. My guess is your chinese is above English, and iTunes picks this up. Drag English to the top. If it is already at the top, I have no idea
didn't work, or was it already set to use English?
Which bit is in Chinese?Already set to English, Afrikaans and Spanish.
The download buttons and text that describes the podcast.Which bit is in Chinese?
defaults write com.apple.screencapture type jpg
defaults write com.apple.screencapture type pdf
Erm ok, where did it put the screenshot?got a screen capture?
shift+command+4 will give you a crosshair to drag around what you want captured. To make like easier change the default save as file type to jpg.
How you might ask - and even if you didnt- open up terminal and type in
obv you can change the jpg to represent the file type you prefer egCode:sudo defaults write com.apple.screencapture type jpgCode:defaults write com.apple.screencapture type pdf
Check your desktop -it should be labelled picture 1.*** <-Whatever format youre using
Have you taken the screenshot yet?No dude, you have to give me like exact commands I can copy into terminal![]()
My command of script is a little rustic if you can imagine.![]()
Try it again? The default is supposed to be the desktop.it aint there
