Java Problem
Mavix
Durban
I'm having a bit of a problem with Java, and it's starting to become rather unpleasant.
In general I hate (Like really, *hate*) Java (I prefer C#), but I have to do it at school.
Now can anyone see *any* problem with the code below?
Code:
try
    int amount = Integer.getInteger("150");
    System.out.println("You entered "+amount);
catch (Exception e)
    System.out.println("Exception: "+e.toString());
Because it keeps printing "Exception: java.lang.NullPointerException", and I cannot for the life of me figure out why.
Any ideas?
BTW, if it makes any difference, I'm running Java 1.6, Netbeans 6.7, Windows 7.
NullPointerException AFAIK means the same thing as Object Not Referenced or Null
Code:
try
catch (Exception e)
Any ideas?
Why are you using getInteger()? Surely you should be using getValue()?
getInteger() assumes the String is the name of a system property numeric representation, and in your case returns null. Thus, the exception.
Err... getValue()? :confused:
You do know that C# is based on Java? In fact many Java code snippets can work in C# without any changes.
Not surprised. Isn't actually based on Microsoft's failed version of Java, which is based on Java? Anyways, I find Java to be excessively slow, and the IDE's (Netbeans at least, haven't tried Eclipse) suck. But that's just my opinion...
Integer.getValue("1234") or Integer.parseInt("1234") would work in your case.
Integer.getInteger("1234") is not correct for what you are trying to do.
Of course! *Facepalm*. My bad...
Thanks for the help!
