Javascript issue - focus() returns TRUE
AmpleHosting
Hello,
Hope some smart people can help.. Having problem with a form validator.
var pass = TRUE
then some checks on fields etc,,,
if one fails then pass = FALSE
then it goes to this piece of code. which seems to returns TRUE regardless...
if (!pass){
var focusHere = document.getElementById(offendinginput);
focusHere.focus();
alert("One or more of the required fields needs to be completed. Denoted by a *. Please complete them, then press continue again.");
return false
BUT
this works like I'd expect
if (!pass){
return false
WHY does document.getElementById or focus() cause this check to fail i.e return TRUE and the form submits?
using Firefox..
Chunkyfeather
Try this:
if (!pass){
alert(focusHere);
//focusHere.focus();
//alert("One or more of the required fields needs to be completed. Denoted by a *. Please complete them, then press continue again.");
return false; //Dont know if it matters, but you ddidnt have a semicolon here ;-)
Is the object being set? Im not a javascript expert or very savvy with it, but im sure if this fails your whole if clause will fail?
crazy_cat
it does not cause the check to fail since its never executed if pass=false which is the case if everything validates i.e all your inputs are valid thus the check (!pass) in effect is (!True) which is false.
The content of both if statements are irrelevant since the check is the same...assuming pass is a boolean.
please explain further or put more code (if you are allowed to)
btw, a mere suggestion - USE jQuery:D:D
crazy_cat
oh if you are using firefox, get firebug as well for javascript debugging
any sane web developer uses it :p
AmpleHosting
Sorry :)
full javascript below that does not do as I expect...
<script type="text/javascript">
function GetRadioButtonValue(id)
var radio = document.getElementsByName(id);
for (var ii = 0; ii < radio.length; ii++)
if (radio[ii].checked)
return radio[ii].value;
function checkrequired(which){
var returntrue = true
var pass=true
for (i=0;i<which.length;i++){
var tempobj=which.elements
var starfound = -1;
starfound=tempobj.name.indexOf('*');
if(starfound >= 0) {
if(GetRadioButtonValue("payment") == 'debit_order') {
if (tempobj.name.substring(0,3)=="do*"){
if (((tempobj.type=="text"||tempobj.type=="textarea")&&tempobj.value=='')||(tempobj.type.toString().charAt(0)=="s"&&tempobj.selectedIndex==-1)||(tempobj.type=="checkbox"&& tempobj.checked == false )){
pass=false
var extrainfo = "for debit order";
var offendinginput = tempobj.name;
if(GetRadioButtonValue("payment") == 'credit_card') {
if (tempobj.name.substring(0,3)=="cc*"){
pass=false
var extrainfo = "for credit card";
if (tempobj.name.substring(0,1)=="*"){
pass=false
var extrainfo = "for customer details";
if (!pass){
focusHere.focus();
alert("One or more of the required fields "+extrainfo+" "+offendinginput+" needs to be completed. Denoted by a *. Please complete them, then press continue again.");
return false
</script>
AmpleHosting
Try this:
var pass is being set/
I've tried that and it works because I comment out focusHere.focus();
but I would like the browser to focus on the input that needs to be filled in.
crazy_cat
Code:
focusHere.focus();
looks for the element by element Id. The value of offendinginput is the name attribute of the form element so line one will return null.
also var offendinginput = tempobj.name; is declared within the scope of each of the above checks within the for loop, thus by the time you actually use it in your final if statement it has no scope!!!!!!
bigger suggestion - refactor your js...too much repetition imo this needs to be seriously worked on
crazy_cat
Example of some simplification
Code:
fillStuff(tempobj.type, ""
pass=checkType(tempobj.type)
if(!pass){
extrainfo.push("for customer details");
offendinginput.push(tempobj.name)
function checkType(type){
if (((type=="text"||type=="textarea") && value=='')||(type.toString().cha rAt(0)=="s"&& selectedIndex==-1)||(type=="checkbox"&& checked == false )){
return false
return true
guest2013-1
guest
+1 to using jquery... you would've been done with this **** already ;)
And I agree with crazy_kat about what the problem is, you're passing it a null value and it will go bonkers. Remember, even if this was server side code, your stuff would fail even if it had a "pass".
AmpleHosting
Figured out this mess..
Thanks for the suggestion to use Firebug.
Was a silly mistake - getElementById requires your form fields to have a id="" tag, which where missing in the form - making the line return null and making the form submit
So remember: you need to give the object an ID if you want to getElementById
