As i said i'm a novice but its an apache server running plesk with host4africa.
I have FTP access
Hope the information is correct and will help
Yes all checks where passed except 1. SAFE MODE is ON and it should be OFF. I have no clue how to turn if off or even if i'm able to.Hi Vegeta, did you pass all the checks before doing the installation?
Joomla said it can still continue. I have deleted the installation directory, should i upload it again and install again? Do i need the FTP enabled during the installation process?
The permissions? On the folder? It's 755... sorry if thats not what you mean can you pls explain.Just did a quick install on our BSD server, running PHP_VERSION=5.2.5. Got the green on all of the options. What is the ownership set to on the containing folder.
REINSTALLED EVERYTHING... EXACTLY THE SAME PROBLEMWhat now?
Say what?This is a possible fix Linq it seems that safe mode should be turned off in your php.ini file.
yup no luckDid you re-upload the Administrator folder. I'm pretty certain something went wrong there.
Say what?Do i need to create such a file? And upload it where?
Is there one by default and i can just change it?
thx for the advice will try that nowI have had this problem several times when doing Joomla sites.
Its usually permissions on the index.php file in the administrator folder , the permissions on the /administrator folder itself or sometimes other files that the index.php file calls.
I may be stating the obvious , but have you asked for the apache error log from host4africa?
This will show you exactly why the 500 error is occurring , and will give you clues on how to fix it. My guess is you will see something like : "xxx.php is writable by group" and then you will know which file permissions to change and where.
Get that error log and then post it here minus details that would compromise your server.
