Autostyle say they deliver countrywide, you can also try them.
Audi B8?
Yes, the B8
Audi B8?
carefull of the oil on the filter, that can mess with airflow sensor. once dry they do allow quite a lott of fine dust in.
humble opinion, not worth it.
Scary... Now do I really want a K&N filter.... Don't think soPRoblem is that oil will go up the tube into engine. In itself not an issue, But that oil hits the airflow sensor, glogs it up. NOw you suck in 10Litre of air, but sensor either Default to error or reads 8 litres or less.
Car runs lean, burn piston. Or you Airflow sensor and the other sensor do not agree with how much air is coming in. so when you put foot down you have that hesitant jerky acceleration.
And all of that for zero gains. not worth it.
I had the K&N for my Audi B5 2.8 V6. No gains. after two months the intake was oily, with dust particles visible. Sensor was glogged and then I broke that fine wire trying to clean it, costing R5000 for new Sensor.
