Keystone jack for DStv wall plate
feo
Pretoria, South Africa
Hi
Trying to neaten up my setup so need some keystone jacks that I can use with DStv.
Pics will explain better what I've bought.
This is the front:
https://www.dropbox.com/s/ebd4nz4dfrwkwj9/Photo 2014-03-30, 15 36 56.jpg
This is the back:
https://www.dropbox.com/s/ko9f17c4qcc3krc/Photo 2014-03-30, 15 37 18.jpg
When I ordered the jack I was expecting the front to be the same type of connector as the back. The normal white coax cables fit fine on the back but the front looks like a normal TV antenna jack.
The keystone jack needs to fit in a Schneider S3000 wall plate adaptor module like the one below:
https://www.dropbox.com/s/wlasw5qd3v1b41g/Photo 2014-03-30, 15 37 32.jpg
Any advice? Have I bought the wrong thing? If so, where can I get the right one?
Satellite feeds from the dish. Right now it only goes into the lounge.
EDIT. How do I purchase from the site in your link?
You cannot us the ones you have for the satellite feeds. Those are for RF only and your IF satellite feeds will degrade badly through them. You need the ones I posted. You can't purchase from the site. They have a Pretoria branch...
Perfect.
And they'll fit in the adaptor module I posted in pic 3? Looks like it would.
Thanks very much dude.
Look forward to my next thread tomorrow on how I can extend my DStv signal to another room. :D
Speak with the guys at Space TV, when you get the modules. They will sort you out with the parts to extend and explain how.
