hi
Thinking about getting a kindle for an elder person in my family, makro has one with adds for R1499:
"Amazon All-New Kindle Touchscreen Wi-Fi 8th Gen"
okay some question as i've never used or even seen a kindle before, i'm thinking of purchasing the above and loading a bunch of books on it (not purchasing through the store) is that possible ?
the person i'm buying it for isnt tech savvy in the least and ofcourse wont have access to wifi etc will that be a problem ? i'm assuming you dont have to be connected to the net to use this kindle ?
whats the storage like on these things, will the onbaord be enough or does it come with an sd slot or something ?
oh another question, can i load any format of ebook or only certain ones ?
so yeah the plan is to basically purchase this and load it with some books and present it to her (gift).
