Kitchen Cupboard doors
JSRJJ
Good Day Experts. Trust you are
Doing well.
Need Your advice on where I can find the material with texture and color as seen in the attached pictures. Mica and builders don’t have it.
Planning to go to Timbercity Randburg tomorrow. I am in Sunninghill. Do not
mind driving far to get what I need.
Sizes of doors below:
368×720×2
920×368×2
Top Filler: 750x95
The guy who did this 2 years back is now flying planes in CT. He asked to visit a store in Pretoria. Will also go there with a sample door and see if I can find.
Thank You.
Timbercity might have, Chamberlains as well..
however, you need to find a specialist board store, who will have a far larger range of chipboard and would therefore be much more likely to have the same board you are looking for.. they would also be able to cut the doors, edge them and drill the hinge holes for your..
A quick Google brings up the following place:
So any place like this one, would be your best bet..
Timbacity stock PG Bison (actually most do) don't worry about the actual stock on hand, they will/should have a display board from PG Bison with all their samples, then pick your board and ask them to order it for you. The boards are large, 2745x1830 so you're gonna have plenty spare, but such is life.
Checked with Timbercity Randburg and they checked with their suppliers and no one has the same finish as it is no longer being produced is what I was told.
One of the guys said it is WISCONSIN WALNUT, linear finish. Will keep looking. I don’t mind if I have to buy the whole board
How can anyone give you advice without knowing the full look of the kitchen?
What advice..? All the OP is asking is where to find the exact same colour and finish boards he already has.. likely to replace some broken pieces or finish off an addition..
You are correct. My bad (and thus apologies).
If you cant find stock then you might have to consider redoing your cupboard doors with a new color.
Unfortunately they discontinue some colors some times.
The one I have seems to be discontinued as said by PG Bison. They don't make it any more. I have to find something that is close match for it. Will keep looking outside of Gauteng tomorrow to see if anyone has a board lying around somewhere.
Places visited so far with no luck:
BOARD KING centurion
BOARD MART centurion
WOOD CENTER Marlboro
HDS Pretoria
Timbercity Blairgowrie/Randburg
Chamberlin Randburg/Clearwater
All those people that have WISONSIN WALNUT on their website is by mistake.
The guy did the kitchen 2 years ago and now this is out of production. **** my luck
Can't really blame the guy who did the kitchen, it's not really on the list of things to check, is when the board colour will go out of production..
They have boards. You could phone them and ask if they have the one you want. I normally go there.
These guys might be the best bet for like a single door if you don't want to buy an entire board. I know they used to cut and sell smaller pieces.
Both in Benoni. Im sure both stock PG bison.
