Kreepy Krauly Pro
Ninja Girl
Johannesburg
I have had three Kreepy Krauly Dominator pool cleaners since late 2021. They are great little machines, but the Dominator has lots of little cogs and gears, so lots of things that can (and do) give hassles and it is pricey. The parts to fix the Dominator is also expensive. So I decided to purchase the Kreepy Krauly Pro with just one moveable part (so that less can malfunction). I purchased it online and the description was not super detailed, even other sites I checked did not mention the following noted on the box: IDEAL FOR POOLS 7M X 4M AND LARGER. I have a tiny pool of 3m by 4m. Will the Kreepy Krauly Pro model be a disaster in a smaller pool?
You should be fine like Mike said but in some smaller pools they like to get stuck in a specific spot. If that happens try changing the tube length and see if that helps. You also get weights you can add to the tube to change things up if the tube length doesn't help.
Excellent! Thank you for the advice.
