Lan connection issues connecting to Citrix after loading 3G USB modem stick device
stanton
Hi all
I am a new user having the following problems :
Lan connection issues connecting to Citrix after loading 3G USB modem stick device.
In our Business we are on a WAN and connect to our Citrix servers in
> the UK via VPN . After installing the 3G USB device and its software
> I could log onto our citrix servers via our eVPN connection but when I
> disconnected the 3G USB device / Modem and then tried to connect to
> the Citrix servers via our Lan connection again I was not able to . The citrix loads and then I have a Blue screen appear but it does not display the log in box for the user to log onto the metaframe .
If i uninstall the the 3g USB Dongle and its software my Citrix Lan connection works again . So the issue definitly lies when i install the 3G usb dongle and its software then i cannot connect via the lan.
Is there anyone out there who is experiencing or has experienced the same issue and has found a working fix .:mad:
Sounds like DNS not refreshing. Does it work after a reboot or a ipconfig /flushdns ?
basically . Before i loaded the 3G modem i ws able to connect to Citrix Metaframe no problem . Then i loaded the 3G modem connected to Citrix via our eVPN portal no problem. Disconnected the 3G modem plugged the lan cable in and was unable to connect.
So it looks like to me the 3G software Overwrites something in the Citrix Settings. Cause when i Remove the 3G software and the device my lan connection works again:confused:
