Robin Hood
Hi..I have a Modem/Router Billion 7100SV..When i do a couple of settings within the router itself, i will have intermitted lan disconnection issues...the light goes off....then will come on after about 3 min....Then off again after about 3 min....then on again..I even had trouble accessing the router..I have tried diff network cards as well as changing to a diff slot on the computer..Sometimes even after doing a "factory reset", i also battle to get in the router....then...suddenly...everything will be ok after about 10 min of battle..Any ideas whether this could "maby" be "setting" related??....thing is....Can a router's "LAN-light" go off even if the SETTINGS are wrong??
tia
tia
