Hi All,
Need some help. I am currently connecting my modem using a LAN cable, but this means I lose some functonality due to the fact that I do not install the modem software and can not use the bandwith monitoring program or signal strenth tester
I do however believe I am getting better speed to my Duel Chip Toshiba using lan instead of a USB port
Any recommendation on the best method of connection ?
