I just turned on my wifes laptop and I was greeted with a quick BSOD (so fast I can even read it) and the lappie just reboots. I have tried almost everything - safe mode - same thing happens; Last know config - same thing. I have booted from the WinXP CD and first I tried to do a Repair - CHKDSK /F and it tells me something about it can’t find the autoex.exe (cant remember exactly, but couldn’t find a specific file either on the HD or CD to perform the check disk) I have thought I would do a repair by reinstalling and when the partition screen comes up it basically says that the partition of 60 gig is unknown and says that no space is being used.
What the heck must I do? Any ideas please chaps.
Grim
Edit: I just tried another CHKDSK and it says AUTOCHK.exe could not be located ont he HD or CDrom - The CD rom is also dead, I cant open it? Wtf
Grim
