Hi guys
I am starting my studies overseas and need to get a lappy to work on (goodbye poor desktop you have served me well
Where is a good place to buy from these days?
and help tracking down what I am looking for is also greatly appreciated.
so because it will be used for graphic and inustrial design work (3d rendering etc) and a bit of animation it needs to be on the beefier end.
I don't have the money for a Macbook pro so please don't bother recommending one. If I could afford one it would be my first choice.
Main requirements:
15" cannot work on 13 too small, and while I would consider 17" my back is already getting phantom pains.
16GB RAM
Dedicated GPU
colour accurate IPS panel (100% SRGB and as much Adobe RGB possible before prices get ridiculous)
SSD
not too worried about CPU as by the time you fulfil my other requirements they seem to be on the better end of the spectrum anyway.
Nice to have if within means:
Display port or thunderbolt 3
>FHD... 1440p etc
BUDGET:
15- 20k but the closer to 15 the better
Thanks in advance.
Main requirements:
16GB RAM
Dedicated GPU
SSD
>FHD... 1440p etc
BUDGET:
Thanks in advance.
