No, No, No, I don't want to permanently remove my beard, I like my beard.
If possible I want to clean up a bit here and there though, the bottom of my neck, maybe higher up on my cheeks etc.
Anyone who did this or who explored it before?
Is it possible, is it practical, is it worthit, or is it uber expensive, very painfull and doesn't really work?
Can they only do it on very specific areas as in would I be able to draw a line on my face and they'll be able to do one side of the line but the other side will stay unaffected?
From the little reading I did so far you have to go for a couple of sessions, each session thins out the hair more and more till you are happy and ultimately after a few months or a year you'll have to go back for a single session.
