laser cartridge
upup
currently offline
I need to replace a laser cartridge on a fax. It is a simple fax. They ask me R750 for one.
I see over the seas their is places refilling it, or refill kits.
Do anyone know where I can get in RSA.
Their is a toner and a drum. Look like a Hp 5L type cartridge.
It is a panasonic UF4100.
the problem with just refilling toners is:
there is a waste bin on the inside of a toner where the excess toner goes when you print.
During refill this wastebin does not get emptied.
Rather buy remanufactured toners if you wish to save money. During remanufacture the bin gets cleaned out.
Also if you refill & something happens to your printer (if still under warrantee) the supplier of your printer will tell you that the warrantee is nul & void.
Reputable remanufacturers will gaurantee their stuff & a few will even repair/replace your printer if it is their product's fault.
Refilling & refill kits are not under warrantee. Even the ink kits from verimark does not come with a warrantee...
