Welcome to telkom where a 1 week project turns into a 4 month wait. I would highly advise against going with telkom (they are known for being a horrible ISP)
2003 called and wanted their statement back.
Nothing wrong with Telkom as an ISP nowadays. In actual fact they usually have a higher FUP than most other providers too.
So telkom just laid some fibre in front of my home last week.
How long will it take to light up. Which ISP do I contact or is it cheaper to go straight to telkom ?
Odd. Last time my line went off, it took Telkom exactly one day to fix the issue. I logged the ticket on a Sunday as well.There is nothing wrong with Telkom when it works. But if you have a problem, getting it sorted out within the next millennia seems to be impossible. I spent over a year trying to get my ADSL line sorted before finally moving to fiber and getting away from Telkom's horrible support.
To answer the OP, unfortunately, there is no way to tell how long Telkom will take. But I would expect it to be 2-3 months if things go well. I say this because there are numerous posts on this forum where Telkom have layed fiber then just stopped working on that area for several months. If you are unlucky, it could be 6 months or more.
