Would appreciate some advice before i try and pull it all out.
My kitchen Mixer is just a cheapo, but has recently started dripping into the cupboard slowly. It speeds up and drips mainly after you switch the tap off (primarily the hot tap). The dripping slows down if the tap is on full.
I have checked the 2 stainless steel supply pipes and they are bone dry. The drip of water is actually forming on and dripping from one of the 2 threaded mounting bolts, which leads me to believe that the problem is inside the tap itself.
Any ideas? Maybe just an O-Ring inside the mixer somewhere?
Much obliged.
Much obliged.
