Leaking water feature
francoisvw
Garden Route
So, I've managed to drop the base of my sparkling new water feature as I was carrying it into the house..
Is there something like a "spray-on" cement that I can use to seal the crack with? The corner is bust on the outside, and a crack running along the seam. The inside seems intact, but obviously leaking through it.
You get cement in a tube - fits in a silicone gun.
As for the leak ..... You'll have to paint the inside with stuff and stick stuff on the paint. (Can't remember the name of stuff)
