[OUPA]MrNutz
hey peeps..
client (about 30 pc's)...
they have a 256k leased line ...192.168.0.x for ip range - use active directory , ISA ect..
thus their dns is internal - and gateway is specified.
now they received ADSL..
the ONLY BASIC suggestion i have (tested this yesterday - works 100% - bit manual but ok)
-get 1 xp pc - in bridge mode ADSL connection
-put CCPROXY on pc(not to be used for anything else than "proxy") but that is part of the domain
-use colasoft capsa to measure bandwidth usage
-then just add to your browser 192.168.0.X:808 (as they only want the ADSL for faster browsing - no apps)
i would have liked to just use the ADSL in router mode - DNS is a big problem then - because i have ActiveDirectory and ADSL router dns settings in 1 tcp/ip setup - its gonna cause problems.
its a REAL small setup - and i need a basic solution - but the above software is a bit manual to keep an eye on. (it works tho)
-they wanna keep the leased line.
-but only give certain ppl access to the ADSL
so main Q: - how do i combine ADSL with leased line with minimal effort/effect ..the MS way
thx
heheh - shame - poor okes received their first 678 this morning
thx
