Led 1156 bulbs
Nuke
After I barely missed a numb nut who turned into the road just in front of me on Saturday, I feel that really need to replace my DRLs. One bulb is blown, so I turned it off. Its currently normal 1156 incandescent bulbs.
Now I want to replace it with high end LEDs. What do you guys recommend? If its the same brightness as my dims, its just as well. I talked to the supplier about this but they only have one in stock. I also came across these.
I don't want to blind someone, that is counter productive, but I want to be sure that you can't miss me. And if it adds to the amount of light at night, even better. (Seems that I can enable it via the VAGCOM)
