Not meant like that, I meant I can see he is using the UPS as the device to supply the power and the external battery banks to supply capacity.
So how many batteries are you using?
This is being built by a friend of mine. Only reason there is a delay is because someone in town bought up all the batteries and invertors. So we are waiting for stock to arrive :/ Im paying the guy R500 a month over a year for what is being builtWill let you know how testing goes
R6k for the year ... And you need 4 hours backup time which means you need 240 amps for 1440kw.
That's not a bad price for rental but since it's a modified sine wave unit, don't be surprised to see your equipment go faulty within that 12 months.
Why would my equipment go faulty?
I want on there is 1310 watts and my UPS that Im getting is only 2.2Kva.
Ive been told I should get 4 hours out of it at 1400 watts constant.
Based on what numbers are you calculating the 30min uptime under the stated load?4 hours? You're insane bro. Eyeballing those numbers I'd say 30 mins max and that is being optimistic.
On the plus side...you seem to be off on the other side too...PC, TV & DSTV is not going to get you to 1300W unless you've got at least 2 heavy spec PCs under full load simultaneously. (For reference a high spec PC idling goes for ~100W so we're literally talking high spec under full load here to reach 1300)
Yes, everything is being supplied, and in its own case. Yeah, my googlefu returned the same results. Makes sense, the guy who is building it has comx as a supplier so I am not suprised he got the inverter from there.
Fear mongering.Why would my equipment go faulty?
Not a bad price that for a 1400w inverter/charger.
But it's not a pure sine wave? Won't that be bad for the electronics?
Its not badly priced if it is 1. Deep Cycle 2. Gel200Ah Lead Acid Battery 12V @ R4,234.99 is that a good or bad price?
How do come to that conclusion without knowing the batteries involved?4 hours? You're insane bro. Eyeballing those numbers I'd say 30 mins max and that is being optimistic.
Dell Monitor 264
Dell Monitor 264
PC Box 500 (my computer has a good high end gfx card. Two IDE hard disks, Two SATA hard disks, a SSD drive and DVD writer)
Large Mecer Monitor 240 (this is attached to the DSTV)
Router 12
DSTV 30
Total 1310
Some of those numbers feel a bit high. Not for the TOTAL kVA needed - could possibly be right, but for the on-going usage -- i.e. monitors are more likely 30-90W I'd imagine in normal usage - although they might spike at 260W as they turn on. Same goes for the PC - may have a 500W PSU, but probably doesn't use all of that most of the time. CPU, disks etc. will all spin down when not being thrashed.
May be worth getting a quick effergy energy monitor or something just to check your usage over an hour or two before buying batteries for that amount of usage.
PS: https://www.energystar.gov/index.cfm?c=most_efficient.me_comp_monitor_20_to_23_inches
Are all around 22 kwh/year at 4 hours per day usage. That makes them around 15W?!
Aah well, I installed it today. I worked all my math on peak usage so as to be sure not to under cater for my power needs. So this is my beast. I call it a beast because it fsking heavy. Requires two people to move it around.
Many places sell those units and you can get batteries for it everyone. Diamel batteries are not needed.
Run it for 4 hours and see if it copes. Then see how long it takes to re-charge, probably about 3 to 4 days.
