LED Projectors
ThatOtherGuy
Somewhere Out There!
Hi,
Has anyone seen the quality/brightness of an LED projector? I'm interested in getting one. What's attractive to me is the bulb life and the fact that it's switches on and off instantly without having to heat up and cool down and the risks that come with this.
I know you looking at 170lm max, but is this sufficient for doing presentations and watching the odd movie?
Also, it seems like these projectors are designed for the small size. On the other hand, you get normal bulb projectors that are also fairly small. Are there LED projectors out there that are not built with size specifically in mind, but quality of picture and most of all brightness? Thanks.
170 lumens... That's around 8% of the brightness of standard halogen bulb projectors out there.
So it switches on and off instantly, but will you be able to tell the difference?
