It sure would!
If you really what to become a pro landscape guy, shouldn't you be shooting MF & 4x5 Velvia?
Take a deep look, it may look clunky, simple and understated, but enthusiasts, whether they will ever afford one or not, acknowledge the M series cameras as masterpieces of design.But it's so fugly![]()
The M8 had a 27 x 18 mm (1.3x crop) sensor and some thought it simply wouldn't be possible to use a full-frame (36 x 24 mm) sensor on a rangefinder, but Leica appear to think otherwise. Their approach is the same as for the M8; use offset microlenses (instead of placing all microlenses directly over the photodiode they are gradually offset as you get closer to the edge of the frame - see below) and to know which lens is being used and apply some software correction.
Below is a diagram provided by Leica which does some way to explaining how microlenses at the edge of the frame are offset from the photodiode below them, compared to a normal microlens / photodiode combination in the center of the frame.
What kind of lenses doest his take? I thought Leica has gone 4/3? Or does it use their full frame lenses?![]()
KJ:"concern about vignetting with full frame?"
there was?
I always thought Leica's excuse for a small sensor in the M8 was primarily because vignetting/light falloff would be too evident with a full-frame sensor in an M-sized body
