LF: Antex P101 Silent Case
PearlJam
Johannesburg
Does anyone know who has stock of this case?
It seems to tick all the boxes for me, but can't find stock. Has it perhaps been replaced with a newer model?
Nobody has stock.
Is this for a gaming PC? If it is I would advise you not to go with a case optimised for silence as they tend to run hot. I had a silent antec and I had to run it with the side panel off. The next build i got a silent coolermaster case and again I have to run it minus side panel. In future I will buy a case optimised for airflow with quiet fans.
No, it is not entirely used for gaming...my son use it a little bit for gaming. I am currently using a Thermaltake Tsunami Dream (which is a silent case if I remember correctly) and replaced the fans recently as I had it since 2006...it is very quiet, but the dust penetration is high.
Your comments are however very valuable. I will just do a bit more homework as I also don't like components running hot as it means reduced lifespan.
I want a basic looking case (no rgb gaming, etc) that is quiet and a decent level of dust protection
Maybe browse the gamersnexus & silentpcreview sites to see if there's something that tickles your fancy.
