LG 55LF650 - Help
Good Day,
I bought the LG 55LF650 television over the weekend from Makro.
Works perfectly well when I play bluray discs or videos through my external harddrive.
However, when I watch DSTV on it (I have the old DSTV decoder - the small box), the video seems unnatural. In some instances it seems to be moving too fast.
Has anyone else experienced this? Is it a TV or DSTV decoder issue?
Thank You.
As Bakkies mentioned, you are getting the "Soap Opera" effect from motion smoothing. You can disable it in the picture settings.
