Hi, these are my current specs:
Intel E8500 - stock
Thermaltake Golden Orb
Gigabyte G41M-Combo (impossible to OC with this mobo)
XFX HD4890 1GB
Transcend DDRII-800 RAM (2x2Gb)
Seagate 500GB SATA
Corsair TX-650W
Before it popped, I had an AMD Phenom 965 Black edition which ran perfectly and I was very happy with it. It raped CoD4 (only game I play) and general windows tasks.
After I replaced it with an E8500/cheapie gigabyte motherboard I haven't been happy with performance, my windows / general tasks are a bit sluggish and my CoD4 FPS is inconsistent. Just for those who don't know, comp cod4 players play on low detail configs in order to get consistent, high FPS settings in order to get the most out of the quake engine. Generally speaking, the better the CPU the more consistent your FPS. With my old AMD setup I got 250 FPS rock solid - chips like a Q9400/QX9650 bla bla will easily do it. Also the new i5's and i7's can do it.
Anyway so my question is, whats the best bang for buck in terms of a performance increase with my current setup. Here are the options I've been considering
1) Replace RAM with something like Corsair Dominators DDR2-1066
2) Buy/trade better motherboard and OC the E8500
3) Just upgrade to i5-2500, 4GB DDR3 1333mhz, entry Asus mobo
So in a nutshell I think my question is am I actually going to get any noticeable improvement in performance from options 1 and 2, or should I just bite the bullet and go for option 3. At the moment I'm leaning towards 3 as I'm not keen to spend money on old tech.
Intel E8500 - stock
XFX HD4890 1GB
Seagate 500GB SATA
Corsair TX-650W
