linksys router problem
Bandit26
DBN
hi i can connect fine using the ethernet cable , but when i try to connect using wireless i get a limited or no connectivity error, i had this problem on the ethernet cable and used the command netsh winsock reset it worked nicely, any hints on wireless or commands to reset just the wireless internet protocol??? thanks
