Linksys WLAN and Iburst
shiwlof
Linksys WLAN and USB Iburst - WORKING
Hi there guys...
I have an iBurst USM modem, and I would like to share my connection wirelessly.
And
I have a Linksys Wireless Router.
Now I know normally you would connect your ADSL router directly to the WLAN router and presto, it works. How does one go about setting this up with an iBurst connection? If at all possible. Remeber I have the USB iBurst modem.
Is there anyway I can setup my PC so that the WLAN router thinks it's an Internet router?
So basically plug my PC, which is already connected on iBurst, into the WLAN router's Internet socket...
I have 2 other laptops I want to share my connection with...
Any help people?
C.
Hi there guys...
And
Any help people?
C.
Um. OK, depending on what you want here, and going by your stated request of "Is there anyway I can setup my PC so that the WLAN router thinks it's an Internet router?", I'm going to prioritise that (which comes at a cost, more later) in something of a (+f)arce about (-f)ace way of doing things.
Short answer - yes, I believe there is; here's how:
1. you plug UTU (USB (not USM, up top) :p) into desktop and set to autoconnect with ICS.
2. you make the Ethernet connection [router] <-> [PC LAN port]
3. you set router to get its internet connection via DHCP
4. you set laptops up to connect as normal to router ..and that should do it!
But now the gotchas:
a. the PC is physically separate from the laptops, no LAN intercommunication between them
b: the PC *HAS* to be on for the 'net connection to be live on the router, and therefore on the laptops.
No go and play ..hope it works out the way you want! :D
Ok cool thanks...
I tried all the steps and the router still can't see the internet connection...
One thing though... and i think I may have made a cock-up... hehe
The cable running from the wireless router to the desktop with my iburst connection... that must be a crossover cable right? Right now it's a straight.
Are you sure about having set up ICS on the host box (the one with the UTU)? You can check this by directly connecting a laptop to it (for which you DO want a cross-over cable: involving the router (which wants to be a DHCP server too) is just going to get messy to manage), setting it to get its address from the host box, getting a [start] -> [run] -> CMD prompt and typing ipconfig; you should get an IP address of 192.168.0.(some number)
It was always a safe bet that you were going to :cool: ..but it's through mistakes that we learn things.
Nyet ..actually, it's unlikely to matter: if lights show up on the network connectors and the router it's a fairly safe bet that the connection is being made.
So now: what model router do you have, anyway?
Linksys Wireless-G Broadband Router WRT54GL
Going to go get a cross-over tomorrow... feel I might move closer then...
Will keep you updated...
Ahhh, old faithful - good on yer! :p Still, good as it is, you can make it a WHOLE lot better with some real firmware - it's not the only one out there, but it's among the easiest to get onto your WaRT and has much community support ...notably here.
You pretty much need that only to test that you have ICS up but it's never a bad idea to have one so get a decent length one, at least in the 5-10m range ...9m too long is infinitely preferable to 10cm too short when it really counts!
it does't matter if it is crossover or not it can be any cable and windows requiers that the IP address for ICS is 192.168.1.1 it must be 1 at the end and make sure that this ip address does not conflict with the router cos some routers have 1 at the end
The fact of setting up ICS will automagically set the host box to 192.168.x.1 (where x = 0 or 1, I can't recall now); it will also run DHCP on that range so worrying about this is wasted effort.
The plan here is to put the router downstream of the ICS box, in effect a DHCP-client so there's no possible way for there to be a conflict. It is also why I said to set the WAN connection of the WaRT to DHCP (where we all usually use PPPoE for a properly/directly connected device). Hell, you could go to town and have the ICS range on 192.168.x.x, with the WaRT network on the same one too ..or (as I do 'cos I loathe typing those numbers all the time when 10.0.0.1 is sooo much easier) :cool: have the WaRT network on 10.0.0.1; or even that 172.something.I.forget too, if that floats your boat!
Ok here is an recap...
- I connect my desktop to the Linksys WLAN router into the Internet socket
- I connect my desktop to iBurst using the PPPOE connection
- That connection has ICS enabled to my LAN port
- I then need to setup my WLAN router, so I connect my laptop using UTP to one of the 4 ports on the rouer and run the Linksys setup application
- In the setup I set the router to connect using DHCP, and I leave the domain details blank
- Everything runs fine until it tries to test my Internet connection
- Keeps telling me I need to check if the connection is active
- Progress can't continue.
On it's own my iburst connection works fine on my desktop, so I know it's connected, but I am not sure if it's sharing it correctly. Tonight I'll use a Crossover from my desktop LAN port to my laptop LAN port, and see if it can connect. Currently the LAN setting are all set to automatic, on the desktop and on the laptop. Should I specify a range, or not?
Possible solution
I was browsing around the net, and I came across this link... http://www.tomshardware.co.uk/forum/8358-18-wireless-sharing-dialup-internet-connection
It explains how to share a dial-up connection across a WLAN.
Would this work for my scenario also?
I live in the middle of nowhere... well, not really, but DSL, Cable,
and WISPs are all still a way off, so dialup's what we have in our
area.
I was given a Linksys BEFW11S4 Wireless Router a while back, and I
have a Wireless card for my notebook, so I thought I would give it a
shot. I'm doing it now, so I can tell you it's possible!
Here's how I did it using the Linksys and WinXP Internet Connection
Sharing.
1. First, on the computer that dials out to the Internet (I'll call
this PC1), install a 100Mbps LAN card. After setting up the card
(Automatic IP or static is fine for now), run the Network Setup wizard
to allow other computers to connect to the Internet through "this
computer." After the wizard runs, it will assign the IP address of
192.168.0.1 to your LAN card.
2. Now dial out to the internet. Once you are connected, open a
commmand prompt and type "ipconfig /all" You should get one result
for your LAN card and another for the dialup connection. Make note of
your two DNS servers, they'll come into play later.
3. Next, connect the wireless router up. Plug a CAT5 patch cable from
the LAN card in PC1 to the "Internet" port on the router.
4. Now, from a DIFFERENT computer (PC2), you need to connect to the
wireless router. I did it by booting my laptop and letting the
wireless NIC automatically detect a Wireless network. After the
wireless connection is confirmed, go to a command prompt on PC2 and do
an "ipconfig /all" Your wireless connection will probably be assigned
an address like 192.168.1.100. If not, you may need to press and hold
the router's "reset" button for about 5-10 seconds and redo this Step
4 process.
5. Now, once you have a 192.168.1.something address on PC2, open your
web browser software and type http://192.168.1.1 and press Enter.
6. You will be prompted for a username and password. Skip the
username and type in the default router password "admin". You'll
probably want to change that later for security.
7. You should be looking at a "Linksys Setup" page. The SSID will be
"Linksys" and WEP will be disabled. You'll probably want to change
that later for security, too. NOT NOW!!!
8. Make sure the "Internet connection type" is set to "Obtain an IP
automatically". PC1 will give this router its necessary data.
9. Click on the "Status" tab at the top. You should see something
like this:
LAN: (MAC Address: 00-00-00-00-00-00)
IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
DHCP server: Enabled
Internet: (MAC Address: 00-00-00-00-00-00)
IP Address: 192.168.0.100
Default Gateway: 192.168.0.1
and so on...
If your internet settings aren't filled in, PC1 isn't configured
properly for Connection Sharing OR you don't have a standard patch
cable connected OR PC1's LAN card is misconfigured.
10. Click on the "DHCP" tab. Find the DNS server addresses you wrote
down in step 2. Make the first one DNS 1, and the second DNS 2. I
put the IP of PC1 into DNS 3 and WINS, but that's so I can tinker with
an in-house testbed Linux/Apache server I have, so you probably don't
need those... feel free. Click "Apply" and wait until the screen
comes back.
11. Go back to the "Status" tab. Click "DHCP Release" and then "DHCP
Renew". Your new DNS entries should show up.
12. Open a new browser window on PC2 and go to a favorite web site.
You should be on the web!
12a. If this fails, check to see if you are running McAfee Firewall.
If so, disable it and try step 12 again. McAfee Firewall can't share
connections through a router due to its inability to detect the other
computers' names. I haven't tried other Firewall softwares for
compatibility. Remember, XP has one built in, but I can't vouch for
it's capabilities or performance.
13. If this process stops working in a few days, weeks, or months, go
back to PC1 and do an IPCONFIG /all again. If your ISP ever changes
their DNS settings, you'll have to redo steps 10-12.
Ouch man... that was a bit harsh hey... sheesh...
Connection works perfectly.
And as an added bonus if iBurst is not dialed up, and I connect on WLAN my desktop dials up automatically...
And just today I spotted a guy trading his USB modem for a desktop modem because Wireless Internet can't work. :) Guess I proved him wrong.
Thanks for everyones input.
It wasn’t intended to be harsh; however you are exhausting every option just to be able to have access to the net...
Sure, you will learn from the process, however it will be far more affordable to obtain a DSL account with a free WiFi modem from Helkom... (and it might just work - most of the time)
Well the process did pay off.
My WLAN is working perfectly.
