Fedora 3 easy setup settings for U630 wireless datacard
When in X windows, run KPPP, under the internet bar.
Click "configure";
Click "new"-->"manual setup"
under connection name type tab type a name "Vodafone"
Click "ADD..." to enter a phone number
enter (*99***1#) for south africa. The number is almost the same for any country. sometimes its *99***3#
Click "Custom pppd arguments..."
enter "novj"
Click "add"
Click "ok"
There should be a "Vodafone" account.
Click "Modems Tab"
Click "new"
Enter a Modem name "MyModem"
modem device should be "/dev/modem" or "/dev/ttyS1"
Click on the "Modem tab"
disable "wait for dail tone"
Click "Modem commands..."
there should be a lot of settings, if all are blank restart kppp. and query the modem.
Change the following modem commands;
initialization string 1 should be: AT+CMEE=1
you can try 'ATZ' also at init string 1.
initialization string 2 should be: AT+CGDCONT=1,"IP","internet"
thats it, this is the settings for vodacom SA.
type in the username and password anything will do.
user: guest
pswd: letmein
and click connect.
Hope it helps
Let me know if it works, but thats how i got it working on a clean full installation of fedora 3 in 2 minutes.
Here are my sources:
http://www.softwarelivre.citiap.gov.pt/Projectos/desktop/config_3g/
