The_Unbeliever
Hi there
Will it possible (once Neotel gets an Ethernet device out) to get a router which will support load balancing between two other ethernet devices?
So that, should Neotel goes down, Telkom will still provide access, and should Telkom go down, Neotel still provide access.
Also, when heavy downloading occurs, it'll be shifted to the fastest, still giving an adequate web browsing experience?
Regards
Libs
Regards
Libs
