Local cap help
AoA
So ive been running a 3gb(telkom) account with telkom for past 4 months for browsing/emails.There are 3 pc's running of the router.
My mobo recently blew so sent it away for for rma,so im using my sisters laptop.
The problem arose when our int cap died lastnight (1st time as we hardly ever use the net)so i thought oh well il just go on some local forums to pass time,unfortunatly i cant seem to connect to anything,getting a diagnostic error with ie 8,this also happens on my dads pc,but never happend on my pc which i used before my mobo blew.
So wondering if u guys have any idea on whats going on before i call telkom,bare in mind adsl still working as i checked it when i switched to my webafrica prepaid.
regards
No cant acces any site.
router ip is 10.0.02
connection ip 41.144.57.140
default gateway 41.144.46.1
dns 196.43.45.190
Have you tried to reset your router? If you go in to the router does it show connected?
Can you ping the default gateway (41.144.46.1)
Set your DNS server to be detected automatically.
Right click on the adapter your using(LAN,wifi)
Select properties
Select Internet Protocol Version 4
Select properties and change to bottom option to "Obtain DNS server address automatically"
Click OK then it should work
